Well, It's not really a problem as much as just a strange occurrence.
I was installing some SDRAM sodimms in a latitude cpt..I got some from ebay which was advertised as pc100 sodimm. I got one that was bga and one non-bga package.
I install both pieces, and I get an error: Memory size has changed, EDO memory detected in DIMM0 near cardbus slot. Press F1 to continue.
I then install each one individually and they both work separately. I then install the non-bga packaged ram with a 128MB pulled from this system together, and it gives the same error.
I figure this ram is not meant to be paired without a similar packaged chip. I know for a fact this board is max 512mb SDRAM.
Anyone else seen this configuration error occur before?
