Strange distoration.
Probably neither.
Did you change your contrast/brightness/gamma etc in windows when using the old cable?
Negative. I'm messing with those settings now from the Nvidia control panel. It goes away when I make the screen darker...but then it's to dark. After playing around with them I'm seeing a big difference.
Maybe there is another util running on your system that is also changing the colour/brightness etc balance ?
