Ok, i'll list the system and the specs.....
My problem is this. While the computer is on and this will happen at completly random times but mostly when it is in the middle of a game. The system will turn off and not crash or restart simply immedietly power itself down as if the plug to the computer was yanked outta the wall.
Specs:
Gigabyte SLI MB
2- BFG Nvida 7800 GTX
WD 200 GB SATA HD
AMD FX55
SB Audigy Gamer
16x DVDR
3 Gigs Corsair PC3200 DDR
Thermaltake 680w PSU
I have in it 4 case fans, 2 fans on the powersupply, 1 fan on the heatsink, and 1 xtra blower fan in the expansion slot.
I have tested the PSU and it seems fine. I get no warning that it is gonna shut down either it just turns off. I keep spot checking the temp on the cards but they never go above 66 degrees Celsius.
I am completely at my wits end its driving me crazy. Any ideas
Specs:
Gigabyte SLI MB
WD 200 GB SATA HD
AMD FX55
SB Audigy Gamer
16x DVDR
