Strange but Annoying Keyboard problem
Bananadog
So i boot up my desktop today and my keyboard doesn't work, okay well i thought, this is annoying, i'll first try a different usb port, that doesn't work either. So hmm, what else, let's try a new keyboard, i take the one i was using on another computer and plug it in and nothing as well. Hmm, well how about some PS/2 or whatever the round purple thing is called, I try that and hey, the numbers lock LED i can turn on and off but no typing. Hmm really odd right? Well, my mouse works, hows about that, i can move the mouse around being plugged in to any of the usb ports i have, including those in my monitor (sweet 21in gateway widescreen)... Alright so i'll reboot and see if i can use my keyboard to get into the bios (del key) or safemode (f8 key). And well look at that, those BOTH work, so i can enter bios and safemode, I can also enter my bios password with the keyboard. So i change the control of my keyboard from Bios to OS, hoping that might fix the problem but it did not. And now i'm stuck, i can't get into safe mode, i can't log into my computer, i can't do anything and none of my 12 USB ports work for keyboards... So here's my question. A) can i get an OSK onto my desktop at the start screen without having to login first or B) can anyone offer up solutions.
P.S. I will try the restore windows or repair rather once i find my XP disk but currently my room is a mess.
ANY help would be appreciated guys, this is my music server so i'm dying here :)
Thanks a ton,
Bananadog.
If you can use the keyboard in BIOS, it obviously works. Sounds like Windows might be having an issue either recognizing it or loading the driver for it. Check your device manager to see if any of your HID or USB devices are disabled. You should be able to do that with just the mouse.
Well I can't check the device manager because i can't log in to windows in the first place, but i'll try rebooting with the PS/2 keyboard plugged in to see if that works
Tried the PS/2 it works in bios like the other one, and then once i get to the login screen i can toggle the num lock key, but typing doesn't owrk, i finally found my XP disk so i'm trying a repair i'll see how that goes
I ended up just having to install a new copy of windows, but, now everything runs faster so it's all good.
