Rocky Mountain High
- Mar 2, 2006
Several posts have appeared in this forum expressing concern over clogged water cooling components. Users of high-restriction water blocks, such as the Swiftech Storm, the Aquaxtreme MP-05 and the Aqua Computer Cuplex XT, have complained about clogged nozzles. Some have cautioned against the use of water block components that contain small nozzles, such as the Danger Den TDX #5 accelerator plate. To prevent clogging of its SF800 flow meter, Swissflow advises the use of a 20 micron filter.
Can anyone suggest any in-line strainers or in-line filters that can be placed in a cooling loop to prevent the clogging of high-restriction components? Such a filter or strainer must be compact and easy to clean. Thanks!
