Ingonuts13
- Jun 9, 2003
Does it matter which you use for inlet or outlet or is it the same either way?
but if they didn't pre-install the sticker, then they would not know for sure that the logo was visable on the final install, and that would interfere with their precious branding of your system.Ingonuts13 said:It's just a shame that Swiftech doesn't let you place the sticker yourself as when I mount it, the logo is upside down. Not that it really matters, just one of those things.
DFI Daishi said:but if they didn't pre-install the sticker, then they would not know for sure that the logo was visable on the final install, and that would interfere with their precious branding of your system.
