Storage suggestions: dual boot and data redundancy.
Dalemite
Here's my situation:
I'm looking to use my home/gaming PC to do a little independent contracting. Some of the apps I'll need to use don't play nicely with my current OS (Vista Home Premium 64) and the OSs that they do play nicely with, I really don't want to use all the time. Thus I'd like to dual boot.
I'd also like data redundancy for my non-system drives/partitions. I'd also like to do this with the fewest additional drives possible.
I currently have a 7200.10 320GB drive as my system drive and a 7200.10 400GB drive for my media. The 400GB drive has the AAK firmware and runs slow, so I'd like to cut that out of the equation. My mobo is a Gigabyte GA-G33M-DS2R (ICH9R).
Should I get a couple new drives, set them up in RAID 1, and partition the 320 to hold both OSs?
RAID 1 like above, but continue to use the 400 as the secondary OS drive (I'd rather try and keep it to 3 HDDs)?
Partition 2 new drives, and set them up in RAID 0 across the small partition and then RAID 1 across the larger partition? OS on the RAID 0, second OS on the existing 320?
I'm a noob to RAID, so be nice if anything I've thrown out there is ridiculous. I'd also like to keep this under $150 or so.
Thanks.
Instead of dual-booting, you could virtualize another OS.
I had thought about that, but I know little about virtualization. My intention is to do some solid modeling/engineering which could put a solid load on the video card. Can a virtualization package pass through to the real video card and not use a virtual piece of hardware? I could always try it first, I guess.
No you cannot access the GPU's capabilities from inside a VM as of right now.
How about you buy
3x WD6401AALS ~$65ea
One for just the OS's make a 50gb partition for the first OS, 50gb Partition for the Second. Leave the rest unformatted.
The remaining two use in a Raid1 for Storage.
