Goal: (Low cost?) NAS box, that I can use as an HTPC in the future.
CPU: G3220 $50 Microcenter
GPU: Integrated
Case: Fractal Design Node 304 or Bitfenix Phenom both ~$70, or Lian Li PC-Q25B $90 - Case might be PSU dependent.
RAM: 2x 2GB from the closet
Mobo: Asrock Z87e-ITX $130 or Asus H87i-Plus $99...Open to other options, was looking for 6x SATA ports which really limited choices. Decently equipped mITX mobo's are all so expensive!
PSU: Would like to re-use my antec TP New 750W if it will fit in any of the cases I'm considering. 150mm x 150mm x 86mm dimensions
HDD: Re-use current 2x 3TB and 2x 2TB drives. Eventually planning on 5x 3TB.
GPU: Integrated
