I've decided that since I'm kind of bad with backups, I thought the best way to make sure it happens is to have a sort of "online" backup. Something that I can run Robocopy or Sync Toy once or twice a day to backup my server (may consider commercial products). My network computers do this daily to the server.
What I would like to do is just be able to swap the online drive once a month with a spare. That way I have two current backups, and one can be stored securely. It also provides minimal pain for consistent backups.
The problem is, of course I would kind of like to run some sort of removable SATA. I already have a trayless drive bay (though it's not really a "hot swap" design). However, it sounds like run-of-the-mill SATA drives don't really "detach" easily, often requiring to shut the machine down. In that case, it seems that USB would be a better solution--it's more universal. Other than the initial backup to the drives, I doubt there would be a substantial amount of data moving, so the slower speed probably isn't a huge problem.
So, what are some ideas? Can I install an inexpensive controller to have the hot-swap capability? Would any of them even work with my plain old SATA trayless bay?
