Hey guys, its been awhile since ive been back on forums but sure enough, i need the help. Just recently (a few days ago) i decided to up my rig. I went from an Opty 165 -> FX-60, evga 7800GT -> evga 8800GTS, and from 2x1GB OCZ Gold PC4000 -> 4x1GB G.Skil F1 PC3200.
Everything has gone relatively smoothly except for the FX-60. Every time I boot up i get to windows (Vista 64) and after 3-5 mins i BSOD w/ a stop error, every time, without fail. The frustrating part is that every time I bsod i get a different error just about every time. Ive searched and searched and have yet to find solutions. Ive tried the FX-60 w/ the old OCZ memory, and the old GPU, and i get the same result. Ive made sure everything is updated, flashed BIOS, and most recently I tried installing SP1 (with no difference, good or bad). I had a problem getting all 4GB of RAM to be recognized. Ive solved that. Several of the error messages have pointed towards RAM issues but ive run memtest fo r 8 hours straight with 0 errors. many of the errors seem to be related with ppl doing either new installs of vista, XP, or server 2003. none of which match my issues or any means of solving.
Oh, I also must mention that the FX-60 runs perfectly fine in safe-mode. and any time that i swap the Opty back in, it runs perfectly fine.
So here's a list of the errors, hopefully one of you great minds can work with me here.
0x00000050 Page_Fault_In_Nonpaged_Area Npfs.sys
0x00000024 ntfs.sys error
0x0000003B System_Service_Exception Ntfs.sys
fltmgr.sys error (didnt write down the error code :sigh
0x000000D1 Driver_Irql_Not_Less_Or_Equal
0x0000001A Memory_Management
0x000000101 (one of my first errors, all others are more recent)
ive gotten the 50, 3B, and 101 a couple of times, but they are all seemingly completely random
after I got the ntfs.sys errors i ran ChkDsk /f on the next startup to check my drives and it came up with relatively nothing. only 8kb in bad sectors.
Ive thought about doing a cleen sweep and reinstall, but I have a feeling im gonna have the problems that others have had with BSODs on install.
Thanks guys!
Thanks guys!
