We need more information to properly diagnose this.
In general, the stop error 0x0000007B is for an inaccessible boot device. Did you perhaps move your hard drive from another system to this system, without reinstalling Windows? If so, you may find this article helpful:
Your boot.ini value has multiple values of windows in it. Did you reinstall Windows onto this device without reformatting? You shoudl definitely reformat completely and reinstall windows. To edit the boot.ini file, right click on my computer, go to properties, advanced, startup & recovery, then click the edit button. Also on the drop down menus, you can set one as default and tell it to not show the list, which will get rid of the menu @ bootup.
Jason
If it were me I would format it again...but then again I can flip a quarter and if it lands on Tails I'm ready to format, and some people are not so eager or able to format at need. If you really don't want to format and hav ea lot of time invested in this already, just set the drop down menus, but if you have the free time or just set this up not long ago and still have more apps to install and backups to restore, I would go ahead and format again just to make sure that everything is just right.
Jason
