Stock voltage on P4 3.4E?
The 478 pin 3.4E's have 1.287V-1.400V for the E0 revision, the D0 have 1.25V-1.400V on the 775 pin they have 1.287V-1.400V for the E0 and the D0 have 1.4V. there ya go.
Thanks for the list. I have a question, the P4 3.4E that I just got is D0, is that worse than E0 or is there really no difference?
well i dont know much about the E0 i have the D0 too, its alright i guess, i cant really test it since my memory limits me from doing a lot of overclocking. But you should check out these guys opinions LINKY to forum
IMHO DO>CO. Simply due to the higher power requirment of the EO. As far as good overclocking results, both seem to do ok. I know many 3.2 DO's hit 3.9-4.1 very easy with good air cooling or basic water.
