stock cooler, Opti's
I'm looking at this processor, but they don't have any more oem's at NewEgg. I've heard the stock cooler is pretty decent. Is that true? Is it good for overclocking? Otherwise I was thinking of getting one of those Zalman Fatal1ty's.
thanks
Your link goes to a ZZF add that has the qx6700 and x6800. If you have the 4 heatpipe cooler for the opty then yes its a very good cooler and will handle all but the very highest O/C and voltage. It will handle the highest voltage and O/C if you short out the thermal sensor on the fan to let it run at 100% but it gets very loud.
I was looking at the Opti 170/175, is that what you're talking about? I also have a Zalman 120mm cpu fan w/ copper heatsink that is on my current system. I modified that one a bit though, it has a small slot machined into the bottom to put a temp probe. I've been using the on chip temp probe so just fill the slot with AS5. There's barely any material gone, it's like 3/1000 of an inch deep, I think, so the AS5 should be fine but I still wonder if it wouldn't be better if it was perfectly flat. Prob go with stock cooler on Opti, and put Zalman on something else.
thanks
