Stock AMD coolers
Ponch
Are the Athlon X2 5000+(Deneb) and the 1055T Stock HSF the same? I am just wondering because I am testing both of my 5000+ with the 1055T Stock HSF. I have not yet set up my H50.
The X6s come with the same heatsinks as the 965 right, the 4 pipe one? Mine came without heatsinks. I know this 4 pipe one works great with my 1050T and the 1090T.
no the heatsinks are no where near the same.. if im not mistaken the 5000+ comes with that aluminum hunk of crap that came with the old x6's and low end phenom I's.. now if you got lucky and your 5000+ came with the 4 heat pipe version then yes they would be the same..
