Still worth getting a 7950 GX2?
Providence
From what I've read, it seems to be a wonderful and efficient card. Even though it doesn't have DirectX 10 support, it's at the top of the 7 series. The 8 series just came out...even if it has DX10 support, is it worth getting an 8800? I'm always weary to get the first in a series of anything...
It depends on your resolution. If you're using a huge monitor which constantly demands more power, by all means go for the 8800. If, however, you're using less than 1600x1200, go with the GX2. You're not going to be missing out on much by not having "DirectX10" in its current state because (a) there's no games for it, and (b) there are no drivers for it, at least not good ones. Also, if you're not using/going to Vista in the near future don't worry about the DX10 part.
Heh. What about this? I'm using two 24" monitors running at 1680x1050.
EDIT: oh, and I do plan on getting Vista soon. But what about my resolution?
So, there aren't any launch issues with these new cards?
I've never used SLI myself, but doesn't it not work with dual monitors?
Does the GX2 act like two separate cards in this respect?
It may be a pain having to enable and disable SLI all the time.
I vote for the 8 series.
Providence: Go with the 8800. If you're gaming across both monitors in span, it'll rape a GX2.
Nobi: I don't own one, but from what I've heard the OS/drivers treat it as a single card.
Huh. I don't actually know much about SLI...my motherboard only has one PCI-E slot. I thought since it was one card SLI wasn't a problem. Shows how much I know.
And there aren't any launch issues or anything? If no one is having a problem with them, I'll probably go for it.
Anyone know off the top of their head what the power consumption is? I've got a 450 watt supply, but I'm only using about 254 when playing Age of Empires III.
Right now, if you're using XP the 8800 is great. If you're using Vista, not so much.
Your PSU might be a little skimpy, but it's hard to tell. If you get a GTX, you need 2 PCIe power connectors, which might be a problem.
A GX2 is an SLI part. It will limit you to one monitor to get the full performance, and in fact Vista will only use one of the two cores as of now. Get at least an 8800GTS.
Yeah, I've only got one of those six-pin connectors.
Reading wikipedia is a bit disturbing in this area...I guess Nvidia hasn't coughed up good drivers for it yet.
Thanks for your replies, everyone! An 8800 that isn't a GTX...shouldn't be too hard to find.
The GTS is just what you're looking for. There's the 600-something MB one and a 300-something MB one. Go for the higher one.
