Still too high priced ? why !
your right ,at this rate it might be only $ 200.00 by xmas.
I ordered my first pair of EVGA 280s through newegg. Returned them for a refund less 15% restocking. $95 tax through newegg.
I ordered 2 from tigerdirect at the same price as newegg's, no tax. :)
Tigerdirect has gotten much better, there was a time when they were terrible, I ordered a 4870 from them and received it very quickly, they also didint charge me tax like newegg (nyc).
Yep, need to shop around. Tiger had one case I was looking at $100 more than newegg.
I love newegg, but wish they didn't charge state tax. :(
Which means the 4850 and 4870 would be like $25 & $50!:D If nVidia launches a $400 GTX 290 in September with clocks around 750/1670/1200 I might sell two of my XFX GTX 280's for $150-$200 to cover the some of the upgrade. Even then I should be able to get that.
The 200 55nm re-spin should be available a few months before Christmas.
$300 for the 290 GTX ?
I'm thinking you might might see it by September. In fact I wouldn't be surprised if nVidia paper launched in around the launch of the 4870x2. I'm just guessing but they had this part ready two months ago, so two more months is enough time to get it out.
The thing with this part would be much higher clocks. If they can them into the 750MHz range at $400, against a $500 dollar 4870x2 it would be very competitive.
I think it's totally worth the $499 price tag. Of course lower is better, but it's worth its current cost. I had a pair of 4850s, and though that setup was great, I really do prefer the single 280. It's a nice card.
You don't have to convince me obviously but why do you think that a single GTX 280 is better?
it may be but its hard to look at it as worth the 500 dollars when the 300 dollar card is nipping at its heels. Also for 300 dollars you can get 2 4850 and obliterate the GTX280 with the exceptions of a couple of games. If it comes down to say less then a 100 dollars over the 4870 (there has always been a premium for the top card) then I could see it.
what I am waiting for is the die shrink for the GTX280, that should change things considerably
Yes, I believe that. I also believe that a single 4870 is better than two 4850s as well. I haven't owned a gtx280, but I've had two 4850s and one 4870, and I could say that the 4870 performed a lot better at high resolution with aa/af.
Yeah, you could go with the 4870 too. My reasons were pretty simple. I prefer a single *quiet* card, NV drivers are a little bit better (for my purposes,) and I just wanted to try it out after it dropped in price a bit. Take the drivers out of the equation, the 4870 is very attractive too. I watch a lot of demo-scene demos, along with other weird OpenGL type stuff, so NV is usually a bit better supported there. I also like knowing I have the extra memory on the card. Once higher mem 4870s are out, they'll be nice in this department as well (if not a little nicer due to memory type.)
