I started a different message thread in here recently about issues getting my HP MicroServer N40L to communicate properly with 4 SATA drives I put in an external enclosure.
Basically, what was happening is that my LSI Logic 9200-8e HBA card I put in the MicroServer would generate a slew of timeout errors in FreeBSD / FreeNAS, v11 and keep "resetting" during the initial boot process.
I finally discovered that if I pulled all the drives out of the enclosure except for 1 of them (and it didn't seem to matter which one), it would boot correctly and see that drive in FreeNAS.
Because I had a relatively unknown situation with the cable I was using to go between the LSI card and the enclosure (back of LSI card is your typical Mini-SAS connector, but the back of this drive enclosure has the older SFF-8470 port on it -- so used a cable from MonoPrice that went between the two connections) ... I decided to RMA the cable and try a different approach.
I ordered a "fan out" Miini-SAS to 4 internal SATA connector cable. And even though this drive enclosure is a Chinese "no name brand" thing? I identified the 4 drive cage and hot-swap tray setup inside it as the iStarUSA BPU-340SATA (which got some top reviews on web sites, some years back). So I connected the 4 fan-out SATA cables to the 4 ports on the back of this cage, bypassing the SFF-8470 port and SATA cables coming off of the circuit card it was attached to. Was *sure* this should work, but nope! Exact same issue!
I even went so far as setting up an old HP Proliant 350G6 server with the LSI Logic card inserted in it, to see if it, too, would do the same thing with a FreeNAS installation. It did - ruling out my initial question about possible compatibility issues using the card in the little MicroServer.
So ..... I guess at this point, people are just going to tell me I have a defective drive enclosure here? And that may be the case. But is anyone out here familiar with ths iStarUSA BPU-340SATA series of cages? Is there a reason I shouldn't be expecting one of these to connect up to a SAS controller in this manner?
