GaleForce
- Aug 7, 2004
I currently have a SATA Raptor 74gb as my main disk. Never installed drivers for it or anything because it worked right out of the box on the fresh setup. I have 2 optical drives on the first IDE port of the motherboard, one a master, one a slave. I'm trying to get an 80gb storage drive to work but it just won't. Originally it only showed up as 32gb, now it won't show up at all.
I believe the jumper settings, from left to right, are limit capacity, cable select, slave, master. Don't hold me to that, but I think its the same on all harddrives anyway. When I put the jumper on the rightmost jumper (master), I get a media test error. When I put the jumper on the second rightmost jumper (slave), I get a media test error. When I put the jumper on Cable Select, I get into Windows, but the drive isn't there. I'm using this IDE drive on the second IDE port of my MSI K8N Neo2 Plat with a single device ATA-133 cable.
Any suggestions?
Any suggestions?
