I just recently purchased a sapphire 6950. I noticed on the red cooler/fan, there is a clear sticky substance on top at the edge of the fan, right outside the sapphire sticker.This is the second card that had this same substance. I returned the first card because I thought it was some sort of defect or a used card. But now the second card has this same small spot of this sticky substance. Is this normal?? I'm about to return the card, but before I did I just wanted to check if this sticky substance is normal as its the second card to have this. Also I saw what looks like fingerprints on the sapphire sticker on the cooler. I'm going to assume that is not normal. Please advise. Thanks
