Sticker Removal
rusty12
I have a sticker on my black Lian Li aluminum case that I’m trying to remove. When I peel up a corner of the sticker it tears and leaves a nasty sticky residue on the case. Can anyone recommend an easy way to remove the whole sticker and any sticky residue it leaves behind?
Cheers
Goo Gone works great, but be careful with a razor blade, its really easy to scratch your case. I'd just use a soft cloth and Goo Gone.
Razor blade on anodized aluminum? That's a recipe for one scratched up case.
The blow-torch joke wasn't too far off. Heat it up with a hairdryer for a minute or two before gently removing it.
