Stick-on VESA mount?
Quartz-1
I've been thinking about a VESA system to mount my three monitors, but my 28" Samsung 4K monitor doesn't have the VESA mount on the back. Part of the price of being an early adopter, I suppose. But is it possible to get something VESA-compatible that will stick or clamp on the back of my monitor?
You could use some automotive 3m double sided tape to attach it. Either that, or you could rig up an adapter where the stand hooks up... that's what I did.
The 3M double-sided tape is magic. Bill Owen swears by it. See if you can't find a basic adaptor plate (one that converts 100x100 VESA to 200x200 or some such) and some 3M double sided tape.
