I just checked and I have 10 days left to step my X58 A1 up tp a Classified. Just check it and it would be $120. Would this help me to ahcheive a higher OC on water?
Possibly. EVGA claims that the classified has super-high-end digital voltage regulation, which is superior to everything else in the world. Are you using a D0 or a C0? If you're using a C0 it might be worth it.
Funny thing is, if you want to go "really extreme" both boards' BIOSes share mostly the same options, including settings for sub-zero cooling. I can show you some links from XS forums where people are really getting crazy with the non-classified.
But my friend that bought the classified swears it's worth it. I believe Tom's and Anand reported hitting some records with sub-zero cooling on the classified. I told my friend that in my opinion, unless he was definitely going to cool sub-zero, it wasn't worth it. I would just save the money and spend it on better watercooling parts or a faster video card. I told him he wasn't really going to see the best benefits the classified has to offer with solely air or watercooling.
Then he said, "Well, I still want the best motherboard out there, and it definitely looks better, too." .... ok. That sounds like it's worth an extra $120 to me....
Do some more research if you're really thinking you want it. Find out if there's some feature or option you just have to have. That's what I would suggest. In the mean time you should read this thread about the amazing stuff people are doing with the "non-classified" model:
http://www.xtremesystems.org/forums/showthread.php?t=221082
Especially note what Solarfall has done with his non-classified:
http://www.xtremesystems.org/forums/showpost.php?p=3780655&postcount=61
And that was early on. I tried to find more recent posts, but there's another thread on the non-classified that he posts on as well, if I recall. Anyways, the X58 SLI is a mean board, and it has almost all the ports and expansion options that the Classified does. I'm not saying the Classified is not better, because it is. I just didn't think it was $120 (or anywhere NEAR that) better than the regular X58 for my needs.
well put!
I have classified and I am super-happy with it although I only use air cooling to oc. I love it because: no turbo throtlling and s3 works @211Bclk and only thing i did when i get stable 4.2g of a D0 is bumpping Vcore to 1.297v without touching anything else!
But still if I have an option of "step down", I will be happy to do it (my e759/760 for an new e758+$120).
After a lot of thought, I just went ahead and decided to step-up. I'm currently #3 in the que, can't wait!
Good choice.
You'll be happy.
I'm very excited to try one of those 8 core CPUs Intel is releasing in Q1 2010 in the Classified.![]()
I can't remember right now, but I I did step up, wuld I need to reinstall Vista?
I reinstalled my OS when I upgraded from the vanilla to the Classified......better safe than sorry............was it absolutely necessary???? IDK.I can't remember right now, but I I did step up, wuld I need to reinstall Vista?
Oops..............wishful thinking I guess.........Yes. You'll be happy with Classified. And the new chip will be six cores
