Hey,
I'd like to ask if anyone here has the steelseries siberia headset. If so, can people around you easily hear what you're listening to? (I work close to others so don't want to bug them).
Also, is the microphone of a reasonable quality?
Now my second question is actually a problem (unrelated to the siberia headset). I updated my drivers for my audio and now my mic doesn't work, all I hear when recording it is a static sound. I tried the following:
- Install old drivers > Problem remains
- Try mic in back connection rather than front > No static but no sound either
- Try old mic in front > Same static
- Try old mic in back > No static or sound
- Try mic in windows 7 rather than vista with OLD drivers > Problem remains
- Try mic in windows 7 rather than vista with NEW drivers > Problem remains
Now before I go out and buy a new headset thinking that's the reason, I'd like to know if any of you have suggestions as to why this problem may be occuring.
Because my old mic doesn't work either I'd expect it to be drivers. But using the original drivers which worked before I updated doesn't fix the problem (even on a clean win7 install).
