Steam’s Shader Pre-caching Feature Exits Beta
Megalith
24-bit/48kHz
If you’re running the stable version of the Steam client, you'll find a new shader pre-caching option that allows Vulkan and OpenGL games to load faster and improve framerate stability during gameplay. If enabled, Steam will collect shaders from your system when needed. Enabling this feature may slightly increase disk and bandwidth usage.
Whenever possible, depending on hardware and driver support, Steam can download pre-compiled shaders for your specific video card. This reduces load times and in-game stuttering during the first few launches of OpenGL- and Vulkan-based games on supported hardware. This feature may use a small amount of additional bandwidth as Steam uploads and analyzes a shader usage report after each run of the game.
I'd rather have the slower load times than have the usage info being sent to steam. I usually play my games disconnected from the net.
It doesn't make much sense why NVidia/amd aren't doing this already with all the bloatware already in their drivers.
So that's how the NSA is going to get video captures of people's computers...
nVidia already does this though.
Do they? I didn't think they did. There are still many games that whenever the video driver is detected as changed that the game has to rebuild all the shaders which means some initial stuttering and/or increased loading times.
