dragonstongue
- Nov 18, 2008
well HT is done through CPU and yes backwards compatible pin count accordingly, this is why AM3 as an example could use a lot of different cpu and AM3+ could as well, they just shift the speed according to cpu installed, they have an upper and lower limit on speed, so for example, if SR will be using the same pin count as Vishera and Zambezi as well as Phenom II, then no problems, AMD did say they will be back compatible, and more then likely they will not need to release new motherboards with a new chipset that is anything but a little more advanced as in sata port counts and such, very much like the 800 series and 900 series are not so vastly different.
from the sounds of it, yes, it will use same socket for opty just need bios update to support.
