Steam problem...I need help plz
ccmgb178
OK so I start up steam and join a 1.6/source server and play for about 10 minutes, then I open up the server list and refresh the servers, no problem yet, then i try to connect to a server and it says server is not responding i retry about a million times and then restart steam...still cant connect to a server...I have to wait about 10 minutes and then everything is back to normal but it just repeats itself..I have Verizon Fios and im using the linksys compact G wireless adapter, with fios they gave me a modem that had wireless built in so Im not using a linksys wireless router. For the life of me I cannot figure out what is causing the problem or how to fix it. If anyone has helpful information, I appreciate your input.
Are you sure you are connected properly to the internet?
Are you having this problem in other STEAM games?
What do you mean properly connected properly to the internet? And yes this occurs for all steam games
