Steam Powered USB Charger in Action
Terry Olaes
I Used to be the [H] News Guy
No, this isn’t related to Valve’s Steam software. This is literally a steam-powered USB charger shown in action with an iPod. Funky and fun. Now where’s the steampunk iPod to pair up with it?
According to the inventor, the thing is based on a Jensen #75 steam engine, which is used to drive a Lego Technic motor. The motor, in turn, feeds into a voltage regulator circuit, providing a continuous 5V charge to which ever USB device you might connect to it.
So you don't have to authenticate over the internet just to use it locally? What a novel idea! ;)
That is pretty cool. I wonder how efficient it is.
What powers the steam engine? I know there isn't a little elf shoveling coal in there.
I'm gonna have to go with 'Steam' on this one. :D
Uh huh yea, but what makes the steam? Is there some sorta chemical reaction there or is it connected to a wall outlet simply heating water to make the steam? Where does the steam come from? The jensen website doesn't seem to say.
When the administration unveiled its new "clean power" strategy, the nerds never thought they were going to get the tail end of progress.
I'm sure calling it a "steam engine" just refer to the way it looks. It's a steampunk design. The motor according to the article is a Logos Technic motor which is battery powered.
According to Wikipedia:
Lego Technic system has always included a variety of different electric motors. Broadly, these divide into those powered by batteries, held in a connected battery box, or by mains electricity, via a transformer. Battery-power is the most common.
Early motors were either 9 volt or 4.5 volt, and consisted of a large brick with a small protruding axle that would rotate when the motor was powered. The motor was not hugely geared-down, resulting in high-RPM, low-torque output.
Recent motors, contain a hole into which an axle should be inserted, enabling axles of different lengths to be used.
In late 2007, a new motor system was released called 'Power Functions'; it was included within LEGO set 8275 Motorized Bulldozer. It comprised a set of motors, two IR receivers, IR remote control and a battery box, thus resulting in a remote-control model. One IR receiver would connect to the battery box whilst the other receiver connected to the motor (up to two motors per receiver), thus remote-control was achieved.
Hmmm I was thinking that the steam powered a little generator that made electricity?
A little geeky, but not very practical.
9v - to mechanical steam - to 5v?
Sounds like the kind of thinking our government uses.:rolleyes:
I really don't understand why we can't edit posts here...................sigh.:rolleyes:
Anyway, I was thinking this might have been better with a small solar cell as the original power source.
Nope, it's an actual small steam engine that drives the Technic motor.
this will be useful when i need to charge my ipod when the world ends tomorrow.
You are right LockeOak. Dry fuel tablets are used. Had a steam engine when I was a young one.
