Stealth Drives?
Xenocide2020
Does anyone have any pictures of stealthed drives?
im trying to decide if i wanna stealth my drives and i was just wondering if the drives stick out at all from the rest of the case?
i just want it to look as sleek as possible.
thanks for your help,
-Tyler
if the drives stick out just slide it back on the rails till its flush. if you want to check to see if your drives will be flush after your done try sliding your drives back half an inch. if they slide back at least half an inch your set.
If the "stealthed" drives stick out of the case, then you've done a poor job of stealthing. I would take a picture of my stealth case but 'rents took my camera away :( .
They found about my girlfriend :eek: !
as Mad_Pyro said, if they stick out you did it wrong, you can trim the bay blank down so its a little thinner, and move the drive back, I use velcrow to attach the blank to the tray, (and ive taken off the front of the tray to give me more room), with velcrow, if it snaps off, nothing braks in the proses, and you can just put it righ back on, also, you can build up the back of the blank over the eject buton, and all you have to do is hit that corner of the drive to eject it.
good luck happy modding
