Stats Stuck
aldamon
Don't shoot the newb :) I haven't tried DC for 6 years so.......
Anyway, two days ago, I started contributing by running the console version on my Athlon 700 file server and the GPU version on my main C2D/X1900XT rig. I let that setup run over night and through yesterday evening. That appears to have established my account, but nothing more. Yesterday, I decided to turn off the GPU version (until it's out of beta) and started up two instances of the console version on my C2D. That has been running for 17 hours or so. Unfortunately, my stats seem to be stuck in limbo. Check it out:
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=aldamon
Am I just being impatient or is there something wrong? All of my instances are set to aldamon and Team 33.
Have you turned in a work unit yet?
Cause if not and then I would assume that's the problem and also folding.stanford.edu updates every hour, [Hard]Folding once every three hours.
I think you are just fine. Just give it time.
At the moment I'm averaging around 70 hours per work unit.
There a lot of small Gromacs being put out so my average is down to 2.7 Points per Hour per Ghz from 3.5 PpHpG when there was a nice mix of work units.
So with only 3 cores running I would expect you to drop around 1 work unit a day if lucky.
Luck ............... :D
Looks like things are working okay now. Your badge is working.
Welcome back to DC !!!
Yeah. I forgot I reinstalled my firewall while F@H was running on both cores as a service. When I got home, both instances of F@H were stalled waiting for the OK to connect. LOL. I'm back in business now. My C2D is working fine, but I question how much value my Athlon 700 file server is adding. It's crunching away, but not getting much done. Every bit helps I guess.
ya, your not hurting anything or wasting electricity if that machine is running anyway.
