Hey I just wanted to see if any of yall had a similar problem and had any advice.
I just got my new Logitech Z-5500's in this week and installed them with no issues, they sound awesome 90% of the time. But that other 10% I can hear a slight static noise coming from the left rear speaker. It doesn't increase when I increase the volume and is pretty soft but definitely audible. Its also intermittent not constant.
I rechecked all the connections 2x, swapped out speakers and still had the noise from that channel. I unconnected the speakers from my computer but still heard static even with no signal playing so its not from my sound card. Any advice, I'm starting to worry I will have to send it back for a replacement unit. Is there a source of interference I could look into?
Thanks yall
Thanks yall
