Static discharge to the case starts the computer
reb00tin
I reach over to press the power button and as I touch the button (or the case) the machine wakes up from suspend. It happens only occasionally. Winters are very mild here, so there is no static problem in this area.
So what’s happening here? Static discharge closes/activates the power switch?
I had a different mobo in that case for years and that never happened. It didn’t happen with this mobo either until recently. The case Lian Li PC-A05N, mobo Gigabyte Z77X-UD5H, PSU Seasonic X series SS-400FL
Any ideas?
Check the ground connection in your home.
It may not cause any serious issue in your PC, but it may cause bigger issue with other electronic components you have in your house.
I'm assuming that PSU is fine in this case.
Check your standoffs. I misplaced a standoff behind one of my boards once and it cause some pretty hilarious teeth grinding on my part for a good day or two. Lucky I didn't fry anything.
Bingo!
It turned out that the problem is the power switch on the A05N case. It's one of those miniature buttons, and static jumps it. I'm gonna try replace it with a regular Lian Li kit switch.
Good going finding out the problem haha.
I am in El Paso currently, very dry and thus a lot of static, sometimes it gets so strong is very painful.
With this Silverstone Fortress case if I touch it while the computer is on and shock is strongly enough it will BSOD the PC :(
I have already killed my Coolermaster Sentinel Advance mouse from the static.
