static charge and usb turns computer on
bandit648
I recently built a new system and I've been have a strange problem with it in last couple months. Whenever I unplug a usb device from the back of the computer it turns itself on.
Also, if I get a static shock when touching the outside of the case it will also turn on.
It even turned on once when I got a shock touching my TV, which is at least 6ft away from my computer. The TV is plugged into the same outlet as the computer. I originally suspected the electrical in my house had some sort of problem, but I have two other computers on the same outlet and they do not do this.
Has anyone else ever seen anything like this?? I'm starting to suspect my motherboard may have some issue.
Here's my specs -
Asus p5w DH deluxe
OCZ 700w gamextreme
c2d e6600
corsair 2gb ddr2-800
evga 8800gtx
Ok, I figured out that USB issue is related to the remote control according to ASUS website.
But has anyone else had a static shock turn on their computer with one of these boards???
I've built several systems and this the first one I've seen this problem with. I've read about people using ground straps on from the motherboard to the case but I've never done that before.
I'm using the black steel version of the ThermalTake Armor case.
That doesn't mean anything. You use the grounding straps to INSTALL the parts.
The little metal risers from the back of your case to your motherboard. Look closely, there are metal rings around the holes this is to ground the motherboard. If you do not have enough of these grounding the motherboard, it will have an open.
Also make sure everything is grounded correctly and connected correctly.
Computers are very sensitive to interference, but not that sensitive.
I used all of the mounting screws and they are all nice and snug. That's what I thought... that the mounting screws are the ground. I'm not using any spacers either. The screws are metal to metal contact on the motherboard.
I didn't have any problems for a the first few months of using the system. When I moved to a new house I started having problems. The room my computer is in has a lot of static.
Get an outlet circuit checker (Home Depot, Radio Shack etc for less than $10) (like this) and confirm that your electric wall sockets are correctly wired - hot is hot, neutral is neutral and ground is not open.
You should have a decent surge suppressor between your computer and the rest of the house too(though that won't fix this problem).
By not using any spacers I hope you don't mean your not using stand offs.. I am not trying to be an ass, but I have seen someone do that b4..
No I was talking about those little washers that sometimes come with the motherboard screws. - I will check my electric outlet I'm using but I don't think that is the problem because I've had two other computers running on this outlet and they don't have any problems.
Thanks for the help......
