StartupRepair Offline/ NoOsInstalled need help booting into Win 7 Ultimate
kortik
ok suddenly I cannot boot into windows
so I put a original win7 ultimate disk go into repair
after it does it thing it says this under detials:
Cannot reapair this computer automatically
Problem signature:
Problem Event Name: StartupRepairOffline
Problem Signature 01: 6.1.7600.16385
Problem Signature 02: 6.1.7600.16385
Problem Signature 03: unknown
Problem Signature 04: 38
Problem Signature 05: External Media
Problem Signature 06: 1
Problem Signature 07: NoOsInstalled
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1033
so I dont know whats wrong been reading some forums
tried going under System Recovery Options into command promt
did this
Diskpart
List Disks
Select Disk 0
List Partitions (look for small partition possibly around 100MB ususlly partition 1)
Select Partition 1
active
exit
reboot
so activated my partition then I did this:
Bootrec.exe /FixMbr
Bootrec.exe /FixBoot
Bootrec.exe /RebuildBcd
still didnt work and I cannot boot into windows Safe mode doesnt work, last configuration optoing doesnt work. System Restore also does not work
I am stuck and have no idea what to do;
Can someone please help?
I'm going through a similar situation with my wife's PC. i wonder if Windows 7's Startup Repair ever actually works.
If you are in the recovery console, do you see the partition with windows? Have you tried doing sfc /scannow /offbootdir=<windows drive - e.g. d:\> /offwindir=<windows drive>\windows
bootrec /scan
I think? There's a switch to scan for an OS installation.
Although I'm guessing that during the booting in to repair it Is finding the OS instance
tried it but now I get this message
File: mvs91xx.sys
Status: 0xc0000098
how do I fix that problem, looks like marvel driver is corrupt or something what to do now?
