where do i go to to mess with the memory timing?
The BIOS... your motherboard's manual will tell you what to do.
There may also be some guides online based on the BIOS you're using.
I wonder if that had something to do with me complaining to them. Ha.
I have read many guides and methods for overclocking through the years, although not to much gain compared to personal chats with people. I know how to overclock, my problem is with the extras around it such as perhaps still being able to let it throttle down to a lower speed even when OCed, to save power.Hey Palm,
No the FOX ONE software doesn't allow you to change voltage. I will give you the same advice someone gave me and it helped. Unistall that software and do it all from the BIOS! Also if you look around forum there are many helpful hints and overclocking methods that I used and they helped 100%. This is my first machine I clocked and I got as high as 3.3Ghz. In 2 days I will try for 3.8Ghz when I get my Liquid Cooling System hooked up
ALSO!!! One thing that helped me stay stable was to make sure you update the memory with the correct VOLTS that it is suppose to use VRAM Voltage.
