Start menu bar on dual monitors???
Pagan Wizard
After about an hour and a half, I figured out how to get both monitors working properly. I now have a couple of slight problems. The start menu bar is only on the monitor on the left, and I can't figure out how to stretch it between the two. Also, how do I switch from one monitor to dual monitors (there are times when I really do not need both running)??? Yes I have searched the forum and google as well.........I don't know if it is because I am getting frustrated or just not looking for the right stuff, but I can not find any info out there to help resolve these issues.
I don't think there's a built in way in Windows to do that with the start bar, I know on Nvidia's side its part of the nView stuff. Probably in the Hydrawhatever ATI has. In any case, you might want to check out Ultramon, google for it. Makes dualhead usage MUCH better :D . As far as quick disabling one monitor, Ultramon is again great for that.
