Okay, so a while back I bought X3: Reunion. I installed, not really knowing (and at the time not caring either) anything at all about Starforce.
I have since unistalled X3:reunion, and thought that I had also got rid of Starforce as well. However as many of you might know, it is not that simple it seems. It started out I was having REALLY long load times, when I first got the game it loaded pretty fast, even outdoor areas. Then I started having random DVD drive (I have an NEC DVD Burner) freeze ups where it would just stop spinning in the drive when I tried to start up Oblivion.
I thought this might have been an issue with the game itself, so I started looking on the internet for a quick fix because the game would refuse to start. I would insert the DVD, start the game up, then the very second I hit "load game" in the menu the DVD drive would instantly stop spinning and the computer would freeze up completely. (not even ctrl+alt+del would work)
After using the google search for dvd spin problems I came across an article about Starforce. I just clicked on it because I was curious to see what it said (I thought starforce was unistalled already at the time) After reading some, I decided to go back into my control panel/system/device manager/show hidden items and sure enough, there were 3 starforce things listed under the "non plug and play" group. I told each one to unistall and restarted for the changes to take effect. I tried playing Oblivion again, the same thing happened. I went to look back in the device manager and they were back. All three of them. So, I went in and disabled them since I couldn't unistall them, restarted and viola!, Oblivion works just fine and load times are back to normal.
I am not saying this is starforce related, but it would certainly seem so. Tonight I am going back and enabling them again to see if I can recreate the problem. If I can, then what should I do to be able to prove it? I would have tested it last night but it was already midnight and I had to be in to work this morning at 6:30 am.
Any ideas from people who know about this sort of thing more than I do?
