Stange Lockups
DocG2828
If this is in the wrong forum, sorry....please move if possible.
This PC is driving me nuts. It keeps locking up and failing to restart....and I can't seem to pinpoint anything. First, here are my specs....
HP m7650n
added 7600gs vid card
added Creative Gamer sound card
I've had the above installed for several months. Then within the last month, the computer would just start locking up at various times....using a wide variety of programs, or even just trying to click on a program from a fresh start. I typically have to manually shut down by holding the power switch. Sometimes it will restart, sometimes it will just run and run and never start back up. Sometimes if I unplug power cord and hold down switch to drain the juice, it'll start back up normally.....sometimes if I let it sit an hour, it'll start back up normally. None are consistent working methods. I've restored the pc back to stock configuration, same thing. I installed Vista upgrade, same thing. Getting old.
I've run PC doctor on everything, no problems. I'm trying Motherboard Monitor right now, but it doesn't list my mb in the setup list. Not sure what else to do. Doesn't seem like it would be software related since I've restored and even installed a new OS.
Could it be temp related? Could I have a bad HD or bad memory even tho the PC Doc checks come out ok?
Any help would be great....any ideas on how to check things further? I really don't want to spend 8 hours on the phone with HP tech.
Thanks!
My first guess would be a bad/dying psu. Pick up a psu tester, Fry's and Microcenter have them.. and I think I've seen them at CompUSA, if there is still one open around you... but that would be the first thing I would look at.
If that checks out ok, try running Memtest for at least 24 hours and see if there are any errors there..
Thanks....I'll look into that too.
Is it possible the psu is simply overtaxed? Its a factory 300w supply. I knew it might be an issue with the 7600gs....but HP claimed this card was tested and recommended even with the psu.
If it were the card though, would i have noticed it right away?
Probably... and regardless, a 300w psu is a little on the weak side anyhow. Typically an underpowered video card is going to show signs of instability immediately..
Either way, an upgraded psu would be a good investment...
