Stanford Messing Up?
tsuehpsyde
I woke up to my stats not updating and I checked and sure enough, I had even more points that hadn't been added into the [H] stats than what I had when I went to sleep. I clicked on my personal stats and they still showed up, but when I click the certs, it shows 0 points and 0 WU's! I checked other usernames and they're doing the same thing. Moose, what did you break? :p
[H] Folding Stats:
http://www.hardfolding.com/?go=38&id=8019&tm=33
F@H Official Stats:
http://vspx27.stanford.edu/cgi-bin/main.py?qtype=userpage&username=tsuehpsyde
Cert:
http://fah-web.stanford.edu/awards/cert.php?u=tsuehpsyde&pts=60932
Full Folding Ahead!
I'm seeing the same thing on the EOC stats site. No updates for my individual stats since the 4AM run, although I know that I've sent an update or two this morning.
meisterbrau
Is this the reason, even though I have completed a WU, that my name is not in the Hardfolding site?
Yeah, hf.com only updates once every 3 hours. With the glitch that Stanford has had pertaining to the stats generation, you should show up in the stats update that is fixed.
Stats are back on track, seems like stanford fixed the problem last update.
1 [H]ard Team, 2 Great Projects, 1 Common Goal..... The Cure
Webmaster: www.hardfolding.com
Lurker Extraordinaire
Yeah, mine are good now but it seems to have glitched on [H]ardFolding's website. It says I submitted over 3k points today, which is wiggidy whack.
Full Folding Ahead!
If it shows it then that is what stanford reported, [H]ard|Folding does't deal in mystery numbers, it uses the data provided.
Problem solved.
The problem was the fact that the user files on stanford's end were not available when the new month started thus it wasn't able to carry over the stats for the new month.
I created a bit of new code to sort it all out, everything should be working fine now.
King_N said:
Problem solved.
That'll show you to question my greatness. :cool: :D Thanks for the fix!
Full Folding Ahead!
Awesome King! You totally rock. I thought maybe we were looking at a Y2K6 bug. lol. Appriciate all your [H]ard Work.
Fold on people! For tuxedoedShrimp
