Tech-Daddy
- Jul 28, 2004
Anyone else having a problem hitting stanford.edu?
AtomicMoose said:Check to see if the server you are trying to report to is up or not.
C:\>ping folding.stanford.edu
Pinging proxy1.stanford.edu [171.67.16.161] with 32 bytes of data:
Reply from 171.67.16.161: bytes=32 time=163ms TTL=43
Reply from 171.67.16.161: bytes=32 time=226ms TTL=43
Reply from 171.67.16.161: bytes=32 time=134ms TTL=43
Reply from 171.67.16.161: bytes=32 time=92ms TTL=43
Ping statistics for 171.67.16.161:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 92ms, Maximum = 226ms, Average = 153ms
C:\>
OSUguy98 said:I had no trouble getting here?
though I did have a WU that is still in the queue.... I tried to manually send it, still wouldn't go.....
Keep on Folding!! For the [H]orde!!
Here is what I get.Tech-Daddy said:Ok.... nslookup from my machine resolves here:
Non-authoritative answer:
Address: 80.245.197.244
Would like to see what others get.
C:\>nslookup folding.stanford.edu
Address: 209.41.168.178
