Well, this prolly isn't the right forum to post this issue in, but since my system is OC'd maybe someone else here will be having the same issue.
I recently upgraded to an Opty 165 and this thing is a beast. I can run it at 3ghz but I'm having divider issues (bios related I think) that are keeping me from going much higher than 2.6ghz.
Anyways, sometimes when I put the system into standby, it just won't come out of it. I originally thought this was a bios issue too, so I reverted back from the 1302 bios to the 1009 on my Asus a8n-sli premium. I thought this fixed the problem, but this morning when I go to turn on my system, no dice.
I should add that this system is solid as a rock and dual prime tested overnight. Its at stock voltage, but bumping it does nothing for this particular issue.
Any suggestions?
Also, I'm about to go to work, so any responses from me won't be until later. Thanks in advance.
Any suggestions?
