Standard Mobo LED Voltage
PoW
What is the standard voltage a mobo outputs to the power and hdd LED's
Are you driving an LED? Then, I don't think it matters. I've never seen a motherboard that needed the LED to have its own current-limiting resistor, so I'd expect the motherobard would source about 15mA, maximum.
Are you driving something other than an LED? Then I think you're doing the wrong thing; you should drive the LED in an optoisolator, then let the transistor on the optoisolator switch whatever load you want to drive.
.B ekiM
Its not the current im worried about its the voltage, i know there are millions of varieties of LED's in the world and I want to make sure I pick up something that is gonna not be fed to much or to little voltage. Due to the lack of responses i assume this isnt much of an issue.
You're worried about the wrong thing, if you're only using the output to drive an LED.
If you're using the output to drive something else, you're still worried about the wrong thing because you should be worried about driving a device the output wasn't designed to drive.
.B ekiM
Talonz said:
No, the worst that can happen is your new led lighting dimly
Assuming he's driving an LED. If he is, then the worst thing that can happen is the LED is shown too much current and it burns out.
.B ekiM
