Standalone power/ Restart switch?
galdoes16
I am in the process of getting all the component together for my next build, of which the case will be the tecnofront HDW bench. Sinch there are no dedicated switch in this open air case, is there somewhere I can buy one, or find a guide to make one?
A PC power/reset switch is just a basic two-terminal momentary switch. You can make your own with a momentary switch, some wire, and some pins and a connector, or you can even just remove the switches from an old junky case and use those. I believe there are also some places where you can buy pre-made switches, but I don't remember off the top of my head specifically which stores.
Radio Shack has all kinds of momentary switches for fairly cheap...or google for "Bulgin vandal resistant switch" for a nice (but pricey) illuminated switch.
Or if your lazy like me goto frozencpu and buy all your front panel switches premade.
