Staggered spin-up vs beefy PSU??
bregga
Hi everyone,
First post on the forum!
Looking to build a large media server - initially with 8-10 SATA 500GB drives, and later add up to another 10 drives.
I plan to do software raid 5 with hot spare using Linux (Fedora?) and EVMS.
(If interested you'll find my shopping list at the end of this post)
With such a large number of drives power will be an issue.
If I understand correctly I either have to make sure my SATA controllers will support staggered /delayed spin-up, since the drain at startup will be massive (with eventually 20 drives, that is).
OR, I have to get a PSU that will be able to cope with this setup.
Do you know of any controllers that supports staggered spin-up? (8-port PCI-X is what I've be looking for - but maybe I should broaden my search...) I initially looked at Supermicro AOC-SAT2-MV8 but from what I've been able to find, it doesn't support this. The Promise SATAII150 SX8 supposedly does, but I've read a lot of negative opinions about Promise.....
Can you give me a good choose for a PSU for my setup or should I go for dual PSU?
I've seen there is 1KW PSU from PC P&C, but it is kindof expensive...
Any ideas, tips or tricks you wish to share, will be greatly appreciated! :)
Shopping list v 0.1
Coolermaster Stacker (T01 or 810 using one or two PSU?)
Asus P5WDG2-WS Mobo
Intel Celeron D 346 3ghz
Icy Dock / Cremax MB-454SPF 5-in-3 (4 of them)
Seagate NL35 or 7200.9 SATA 500GB (8-10 of these)
PSU???
SATA Controllers??
A little more research and googleing gave me a good alternative for the "beefy PSU" alternative.
Zippy PSL-6850P giving 60A :eek: on a single rail should be sufficient even for 20+ drives, right?
Any good alternatives? Would I be better of going for a dual PSU setup?
i know a few people here have said that psu is pretty darn good. personally, i would recommend PC P&C 1kW. gotta love the triple 12v lines.
Ahh, well - here my lacking knowledge shines through.... What are the advantages to having 2, 3 or even 4 rails, as apposed to a single rail?
If there are 4 rails at 15A each, is that the same as one rail at 60A? :confused:
Sorry, if this is a really stupid question. Just point me in the right direction....
power supplies are not my fortay, but as far as i am aware, more rails allows for more overclocking as well as better stability in the system. i think that is right, but im not 100% sure.
Asking around in the PSU forum would produce better results. Here's my take on rails, though:
Multiple rails allows a guarenteed number of amps for individual devices. Say you have a split-rail PSU - 2 12V rails, one at 18A, and one at 15A. The 18A could go directly to your motherboard, and provide it with a guarenteed 18A at all times. The 15A could go to power your drives, video cards, etc. The benefit here is that, when overclocking, your board may require a bit more juice - Something that would normally be taken from the drives, leading to corruption or failure. With the split rails, that's not possible.
This is how I understand it, and would love to be "shown the light" if it's incorrect.
protias said:
power supplies are not my forte
FTFY ;)
Drives only take 25W max, mostly on the 12V rail, at startup. Thus, even for 20 drives, you only need 500W for that, or about 25A. The Supermicro doesn't *appear* to support staggered spin-up; it spins all 4 disks I've got on it up at once. However, this may be deceptive; I don't know whether it would spin up every disk or 8 at once if I had more than one controller. Perhaps Ockie will stop by; he built a very similar machine, Galaxy 3.0, using the Supermicro controllers.
The 1KW is overkill, and a bad choice for this. Using it on a Celeron system would lead to woefully bad imbalance on the consumption of power on the three rails, which is bad for the power supply. I'm using the Enermax 651GP-VE for a similar (but smaller) system, and it works fine. Only 36A@12V, though, so you might want to consider something larger - that Zippy looks nice, but it's $350ish. Two of the Enermax supplies might be better, but you'll have to find a way to connect them (the CM case may come with the connector you'll need, I forget).
Have an Enermax that's been running 10 drives with simultaneous spin-up for the last 2 years just fine (EG465P, IINM).
Probably helps that it only has a P3 650 and a TNT 1 :D
I've run 11 hard drives including 4 raptor 150's along with an fx-60 @ 3.0ghz/4GB RAM/2x SLI 7800gtx 512mb overclocked, touch screen LCD, mutliple fans, and a dfi expert off a pcp&c 510SLI. It should handle 20+ hard drives with ease.
My current psu, Zippy 700w which I have done minor mods to, will run even more drives.
