I have quite a few laptops of different brands and models (a few being IBM T23's) and am currently using them as test boxes for different temp server setups. Being setup as servers I have no need to use the screen or keyboard.. I just SSH in. So here is my questions..
Given the heat that laptops produce near the bottom of the unit would it due any damage to the laptops to have them stacked upon one another? I have probably 5 that could be stacked, and all of the fans blow to the sides or back (none looking for air on the bottom). I could take the batteries out too if that would help. Would this cause the plastic casing of the ones underneath to turn color from constant heat? Or damage them in any way? Right now I just have them all spread across a few tables but it takes up tons of space. Thanks in advance for any suggestions!
