Stacking 90 Degree SATA Cables And Inverting Orientation?
tackyjan
Hi All,
I have a quick question. I have a Rosewill Legacy U3 Micro ATX case.
Currently I have a hard drive installed in this case mounted on the bottom so that it's lying flat. In order to connect the SATA power and cable connectors I purchased 90 degrees cables for both rather than bend straight cables (there isn't much room either from the connector to the side of the case).
I am thinking about getting a new motherboard: MSI A88XM Gaming. If you look at the SATA connectors they are all on the back.
th
I have a question regarding SATA connectors for this motherboard in general and also about installing this motherboard in my Rosewill case:
1. The SATA connectors are on the back so I would need to get 90 degree cables (due to the lack of room in my case). If I ever needed to use the connector either above or below an already used connector how would I be able to stack 2 90 degree connectors? Wouldn't they hit each other? Or would I have to get a "left" 90 degree for one of the connectors?
2. To make matters even more confusing for me, since my hard drive is mounted on the bottom of the case and I also need a 90 degree SATA connector for that wouldn't I need a 90 degree to 90 degree "left to right" cable?
Thank you,
Jan
For problem 1 you could use a ride side angled connector. I do not see a right side to left/right angled cable, there might be one around but I'm not seeing it.
