Stackers 4 - 3 Module Fan Rattle
lw3d
I bought an extra 4 - 3 module when I bought the stacker. It has never worked and even spinned
I tried playing with it, and now it spins a little but rattles ...
It looks like the center piece of the grill is blocking it but I am not sure
Anyone have any ideas how I can fix this
How do you take off the fan and grill? I see now screws at all
No idea, I tried looking at mine to see how I could do it because I hated the LED's on the fan and I could not determine how to take it apart as such.
There are no leds on any of the stacker or 4 - 3 module fans
So does the fan work fine when you take it off the 4in3 module and remove the grill?
Anyone, I need to know how to take this fan and grill off because the fan is broken and I am getting a replacement
the instruction leaflet that came with the case details this, too:
pull the module out, and look behind the front plate. in each corner, you should see the tail end of the pushpin, with 4 petals and a central tab. push the tab to allow the petals back inwards, and slide the whole thing out. repeat and voila, disassembled.
and the FAQ:
http://www.coolermaster.com/index.php?LT=english&Language_s=2&url_place=faq&ftype=&xs=21&serial=106
it's generally frowned upon to insistently ask questions that you could have easily researched. or read the manual. or fiddled with.
