raygan_gamer
- Sep 26, 2007
I'm about to add three 120mm Yate Loon D12SL-12 side fans for my Stacker 830 ...could use some inspirational build/wiring ideas to keep wirings clean and manageable.
should I splice and solder them together?
what is the best way to connect them?
I don't have fan controllers. but I remembered that the IP35PRO has six fan connections and a program to control all of the them= Abit EQ???
Will this work?
any suggestions?
I tried it out last night, connecting them all on 4-pin to the PSU 4-pin...it was noticeable---but not too loud compared to my other pc running 3 80mm Antec Tricool....I play/work with headphones and PC is in a play/work room very far from anyone's bedroom.
advance super-thanks
Will this work?
any suggestions?
