So I've got my stacker on the way and I'm planning on migrating everything over from my 900. Right now my plans have the PA120.3 mounted in the front of the case, with a shroud and 3 fans drawing air in from the front mesh. It will then be going to the D5 pump, to the fuzion, then 2 EK 8800GTS'. My first dilemma begins here; I have a spare siwftech mirco-res but i also have a DD derlin fillport on the way, but I'm not sure which I wanna use. I've heard that using a fillport is alot easier but that bleeding it is a bitch, so any input on that is appreciated, the tubing I'll be using is 3/8 ID and 1/2 OD. Secondly, since the PA120.3 is gonna be in the front, I will only have enough space for a optical drive and the front usb / power button. I have a raptor and a barracuda I will need to place somewhere in the case, so any sort of mounting suggestions are appreciated as well. Other than that, I think im set, so thanks in advance guys!
