Argh...
My gear arrived and I've been putting it together. Aside from Coolermaster supplying some 5.25 > 3.5 brackets (for the floppy) that didn't have pilot holes for securing... (Doh) It has gone without a hitch.
First off I fitted the X1900; with a little argy bargy it fitted perfectly. I then came to fitting the X-Fi, it wasn't having any of it. The actual braket is the same length as the cover brackets, but when I install it, it will only go so far down. The card does not correctly seat.
I was wondering if anyone had the same problem and what solutions are available. I'd rather not have to hack my X-Fi to bits because of something completely out of my control.
Many thanks
Many thanks
