Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
what fits in the stacker 830? I want to setup watercooling in it but it appears there are clearance problem.. and pics or mods i can do so I can get a Rad in int?
I'm going to make a few tweaks to it like:
Put the pump on case floor.
Turn Rad up other way so barbs at the top, help prevent air pocket in rad.
Give the Storm first connection from rad.
Move HD to/close to where pump is now.
Put Panaflo M fans to front of rad to push air instead of pull. Remove inside fans.
Reseat storm
